how hard is it replace egr
Old Dec 30, 2003 | 12:15 AM
Gary97Z's Avatar
Question how hard is it replace egr
I have a ses light and the autozone computer says its the egr valve.are they expensive? what about changing one out? i change my oil and other than that i dont do any work on my car.also i heard there was a recall on them but the local chev dealer says there isnt one
Old Dec 30, 2003 | 12:22 AM
AsianSensation's Avatar
Tell them policy number P00096.
Old Dec 30, 2003 | 12:32 AM
1msfyter's Avatar
took me about 10 minutes to replace. reach behind intake with a 10mm wrench and socket if I remember correctly. pops right off
Old Dec 30, 2003 | 08:10 AM
IslandZ's Avatar
It's 13 mm
But yeah it takes all but 3 minutes.
Old Dec 30, 2003 | 08:28 AM
GREGG 97Z's Avatar
I had my EGR valve replaced at no charge on my 97 about two years ago under a recall notice I received. EGR is part of the emmissions system so I'm pretty sure they have to replace it up to 100k miles if it goes bad. Maybe check with another dealer.
Old Dec 30, 2003 | 10:33 AM
Hyperspeed97z28's Avatar
Two bolts and some new RTV, its so easy to replace...
I'd look into it and see if the dealer will replace...
Old Dec 30, 2003 | 10:46 AM
Gary97Z's Avatar
RTV? i called the chev customer assistance and they said it should be replaced. so they made me an appointment with the dealer that first said it wouldnt be replaced. im sure they will give me problems.
Old Dec 30, 2003 | 10:53 AM
As long as they have the policy numbers, they shouldn't give you any hassle. When I got mine replaced, they never heard of it until I gave them the policy number. It wasn't really a recall that's why most of the dealers never heard of it.
If you got a new EGR valve, it'll come with an EGR gasket. So I'm not sure why you would need RTV.
Edit-Unless you cleaned out your EGR and reuse it.
Old Dec 30, 2003 | 12:28 PM
Gary97Z's Avatar
so did they just replace it or do they just check it and see if its bad? cause knowing this dealer they will just look at it and say its fine.by the way what is rtv?
Old Dec 30, 2003 | 12:57 PM
They replaced it in my case. After the header install, I replaced it twiced myself (headers were the cause, didn't realized it). I finally said screw it and did an !EGR.
RTV=Room Temperature Vulcanizing (ie silicone that doesn't require heat to cure)
HectorM52
Jul 30, 2017 11:46 AM
edman
Mar 13, 2015 09:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
thenewkid
Nov 18, 2014 12:57 PM
CobraEatr
Jul 29, 2002 11:46 AM
