How Hard is it to put Rocker Arm Studs in????
Old Jul 10, 2003 | 04:42 PM
eXo24's Avatar
self explaintory did a search to no evail... but do they have to pressed in the head? or they screw in kind... if you read my post below you can see i am having problems....
Old Jul 10, 2003 | 04:52 PM
GetaZforgetGT's Avatar
I'm fairly confident that the 97 had screw in studs but I don't know for sure.
I didn't think that GM use pressed in rocker stud in any of the 4th Gens
Hopefully someone that has first hand experience can help you out.
Buttercup's Avatar
Haven't read your other post but they are screw in studs.
Maybe I'll run into the other post
Old Jul 10, 2003 | 09:58 PM
Bud M's Avatar
Nothing more than unscrew the old ones, screw in the new ones. If I remember right they should be torqued to 55 ft/lbs.
Old Jul 11, 2003 | 07:33 AM
94 NO TOP Z's Avatar
and put thread sealer on them when you re-install them
Old Jul 11, 2003 | 08:04 AM
You mean Loctite, right?
HectorM52
Jul 30, 2017 11:46 AM
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
