How Hard is LCA Install?!?! 1 to 10?
Old Nov 10, 2003 | 11:32 AM
96redformula7's Avatar
I am going to be ordering LCA's. Can I change them out myself and if so how hard or easy is it. Is it something anybody can do?
Old Nov 10, 2003 | 11:38 AM
Gripenfelter's Avatar
I'm gonna say 3 just because its tricky getting the axle the right height so that the holes line up.
Cuz once you jack up the car, the axle will be a different distance away and its sometimes a pain to find the right height to get the bolt in. Especially if you have relocation brackets.
Other than that its pretty straight forward, 2 bolts.
Took me 15-20 mins on each side including jacking it up.
Old Nov 10, 2003 | 11:42 AM
94 CAMRO Z28's Avatar
It took me a couple hours but thats just because over 2/3 that time was spent trying to get one rusted nut loose on the driver side. I even broke a socket with a breaker bar! Eventually I got it though. Its very straigh forward and if you dont run into the probelms I had you should be able to do the whole job within 1 hour. I suggest soaking the nuts/bolts over night.
Aaron
Old Nov 10, 2003 | 12:04 PM
What do i need to soak the bolts in.....I am going to remove from front swaybar to. What stuff do I want to soak the bolt in. Liquid Plumber?
Old Nov 10, 2003 | 12:05 PM
Brandon 95 Z28's Avatar
I usually just use some WD-40,
Brandon
Old Nov 10, 2003 | 12:18 PM
Any liquid penatrant will work. Liquid wrench works well. Stay away from WD-40. Its better then nothing but it really doesn't eat away the rust like others will do.
Aaron
Old Nov 10, 2003 | 12:19 PM
Hyperspeed97z28's Avatar
PB blaster
Old Nov 10, 2003 | 12:39 PM
95_RipperZ's Avatar
I PB blastered mine and took about 30 min total.
ease = 2.
Old Nov 10, 2003 | 02:28 PM
Chuckels's Avatar
Yeah its a really simple mod. I didnt use any kind of penatrator and it took about 25 minutes. If you do use a penatrator use PB Blaster
I'm with Aggie about a 1.5
Old Nov 10, 2003 | 02:46 PM
x7x7's Avatar
I'll give it a 2 because I had to snap a rusted on bolt to get one side off. Luckily they had them in stock and were cheap at the local dealer.
Old Nov 10, 2003 | 03:08 PM
Detroit808's Avatar
Thumbs up
yep, it's easy enough to do it yourself.
Old Nov 10, 2003 | 03:45 PM
atljar's Avatar
Cake if you have the right tools (impact werench) If doing it by hand it may be a little more tricky b/c of rusted bolts. Just lube them up and shouldnt take too long at all. Good luck.
Old Nov 10, 2003 | 04:31 PM
Originally posted by 96redformula7
... Liquid Plumber?
That made me laugh!
No disrespect meant
Old Nov 10, 2003 | 04:53 PM
ledfootz28's Avatar
i didnt use any penetrant on my bolts.they had rust on them but nothing that my wrench couldnt handle taking off.i agree the only pain is finding the right height for the holes to line up.it is very straight foward though 2 bolts on each lca.
Old Nov 11, 2003 | 01:46 AM
Ah....my bad I meant liquid wrench....back off alright!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jason Short
Jan 19, 2015 06:34 PM
Queens94z28
Dec 20, 2014 09:11 PM
