How hard is it to get the manifold bolts off?
Old Jun 25, 2003 | 11:17 PM
speed76demon's Avatar
the ones connected to the heads?? my car now has 100k on it do you think if i spray them with some pb blaster they will come right out? I dont feel like breakin a bolt off in there thatd be real bad..
Old Jun 25, 2003 | 11:27 PM
Z95m6's Avatar
i sprayed mine for a week or so before i did my headers. They all came out except the alternator one it broke. I didn't need that hole anyways especially now that i got the new motor. My car had 100k on it.
Old Jun 25, 2003 | 11:31 PM
anasazi's Avatar
soak them REALLY good the night before, then the morning your going to start working on it then soak them REALLY good again and then start working on other parts of the car... my bolts came out super easy, 60k miles
Old Jun 25, 2003 | 11:44 PM
Dave Feerst's Avatar
Not too hard, AN offset wrench helps, They are SAE BTW, I used 15 mm on the first few and it worked finr but I think 9/16 was a tighter fit. Make sure you De-torque in reverse torqing sequence or you may warp the manifold.....And dont do it with the motor even remotely warm...
Old Jun 25, 2003 | 11:48 PM
AENIMA95z28's Avatar
did mine on monday, soak em up real good the day before the job and you will be fine.
Old Jun 26, 2003 | 01:57 AM
1982z28with18s's Avatar
Soaked mine the day before with knocker loose and they all came out fine. I had 69,xxx miles on the car at the time.
Old Jun 26, 2003 | 04:41 AM
Laymaster's Avatar
Mine came off pretty easy. I didn't spray them down at all. I used a torque wrench some extensions and a universal joint. It was a little hard getting to the last bolt but I believe I got that one from underneath.
I only used PB Blaster on my Y-Pipe bolts.
Old Jun 26, 2003 | 05:06 AM
Zepp's Avatar
Mine came right off too. No problems at all. I didn't have to spray them either. Car had 80,000 miles on it. But now I have my NEW 383 Stroker with only 400 miles on it. Awesome!!!!
Old Jun 26, 2003 | 05:21 AM
magius231's Avatar
as said above, soak the night before and the morning of. I wouldn't spend too much time soaking the Y-pipe bolts because your going to break them anyway, so just keep that in mind if you are wanting to put it all back together.
Old Jun 26, 2003 | 09:01 PM
Laymaster's Avatar
That's not true.
I sprayed down my Y-Pipe bolts with PB Blaster from NAPA (came HIGHLY reccomended from this board) and I used that electric torque impact gun that everyone made fun of, the one that plugs into your cigarette lighter and you use it to change your tires....
That thing packs a punch lemme tell you. It took the y-pipe bolts out for me, 110,000 miles, and didn't break a single one.
Old Jun 26, 2003 | 10:01 PM
magius231's Avatar
I would say your in the minority by far...everyone I know that has done headers has busted at least one bolt and more like 3 or 4. I soaked mine to death for 2 days beforehand and I still broke all but 1 of them, so it was really just a big waste of PB Blaster.
Really if your not planning on reusing the stock stuff, its actually faster just to let them break off so you don't have to turn them all the way out...least for me it was
Old Jun 26, 2003 | 10:51 PM
cjksflorida's Avatar
Torque wrench
laymaster,
Where did you get this electric torque wrench from, I haven't seen one and would like to check it out. Thanks
Chris
Old Jun 26, 2003 | 10:59 PM
SCgreen94Z's Avatar
I did mine at 115,000 miles.
Soaked all the manifold and y pipe bolts with PB Blaster the day before.
Used hand tools only in removing everything. Nothing broke.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 18, 2014 12:57 PM
