How hard is it to change the gasket on my headers?
Old Aug 20, 2003 | 10:29 PM
stang_killa94's Avatar
Is it a hard/long job to replace them? I was thinking about unbolting them and move them just a little and change it and bolt them back on will this work or will i have to completely remove the headers? Is there any special oil or cream that i have to put on the new gaskets?
Old Aug 20, 2003 | 10:33 PM
Spinner's Avatar
loosen bolts. Remove old gasket. clean surfaces (denatured alcohol works great). slide new gasket in, retighten bolts.
Old Aug 20, 2003 | 10:44 PM
cool thanks
Old Aug 21, 2003 | 08:57 AM
EviLBoX's Avatar
Just thought I'd add that using Fel-Pro gaskets makes changing them a lot easier. Since the holes on both ends of the gasket are slotted, you can leave both end bolts in the header and just slide a new gasket in.
Old Aug 21, 2003 | 09:38 AM
Hyperspeed97z28's Avatar
Mr Gasket. Ultra seal's are like that too... Its so easy
PCLZ28
Dec 24, 2015 05:19 PM
armedtrigger
Feb 24, 2015 08:30 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
