how to get wp out of housing
Old May 5, 2006 | 03:39 PM
jkrouset's Avatar
having a little prob with it not wanting to come out tried to use a press and the whole pump started to bow and cast wont last long if i go any further and info would help is there anything else holding it in?
Old May 5, 2006 | 05:04 PM
Wolffman's Avatar
Re: how to get wp out of housing
Excuse me if I'm reading this wrong...but why are you trying to get it out of the housing. Brand new assembly for $97 ready to bolt on. I might be confused with what you are trying to do. Please enlighten me!!
Old May 5, 2006 | 05:10 PM
slimdawson's Avatar
He's probably converting to electric. I just pressed mine out. Just brace it up as best you can.
Old May 5, 2006 | 05:12 PM
Colin91Z's Avatar
He is removing it to install an electric water pump I'm guessing. Mine came out in a press with no problem. Are you trying to go the wrong way or something? I pressed mine from the center shaft in the impeller out. Remember, it comes out of the back of the pump, not the front. If you are pressing from back to front, you will break the housing.
Old May 5, 2006 | 06:12 PM
jkrouset's Avatar
im pressing on the shaft that goes into the timing cover out and yes im installing a electric wp i took all the bolts out in the front cover is that all there is or is there anymore?
Old May 5, 2006 | 09:00 PM
nb 96 z's Avatar
Yeah it can be a little tricky. I know I wailed on mine pretty good. Just be patient and use a punch and give it a few good wacks.
Old May 5, 2006 | 09:42 PM
Dave89IROC's Avatar
if I read this right, you are pressing from back to front?
if so, stop, you need to press from front to back
Jeff1904
Jun 5, 2016 05:00 PM
Jake Bialke
Sep 24, 2015 11:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
raroz28
Sep 8, 2015 06:10 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
