How to get the steam tube plugs out of the back of the head?
Old Aug 16, 2005 | 07:10 PM
97s10ondubs's Avatar
Ok I know im dumb for even running w/o one, the previous "owner" took the damn thing off, and I want to put it back on but I cant get the plugs out. I keep breaking 1/4" drive extensions trying to get it off. Any suggestions?
Old Aug 16, 2005 | 08:52 PM
FastZ8's Avatar
Re: How the hell to get the plugs out of the back of the head? Need to put steam tube on.
if your talking about the coolant passage in th back of the heads you need a good open wrench that fits PERFECT! and then just pull hard until they come out.
Old Aug 16, 2005 | 10:23 PM
How do you get an open end wrend on a female square drive plug?
Old Aug 17, 2005 | 08:30 AM
thats what im saying
Old Aug 17, 2005 | 08:42 AM
So the square is 1/4"? (I didn't really know) Have you tried a 1/4" breaker bar? If the heads were off, you could take them to a shop.
Old Aug 17, 2005 | 11:15 AM
i broke two 1/4" breaker bars, a few 3/8 to 1/4" adapters and a 1/4" extension. I think they welded them in lol.
Old Aug 17, 2005 | 12:44 PM
sbs's Avatar
sbs
There was a recent post on this on CF, and somebody said they are 5/16"
This is what you need:
http://buy1.snapon.com/catalog/item....8&group_ID=259
Even with the right tool they are supposedly not real fun.
Old Aug 17, 2005 | 03:17 PM
OBE1 95Z28's Avatar
Re: How to get the steam tube plugs out of the back of the head?
If you can get heat in that area, they may loosen up any sealant that was sed.
Old Aug 17, 2005 | 07:17 PM
ill get a torch on it, and check to see if anyone has that tool locally
Old Aug 17, 2005 | 07:57 PM
#7's Avatar
I tried torching and wax melted into it,was breaking my tools also on some of these little bastard plugs.
I got a high speed lathe bit from a friend,tool steel real hard stuff. They can be had in 1/4".Nice and square and hard. I put that in the plug and a big cresent(adjustable open end) on it and took the little bastards out real quick.
These bits will even bite down deep into the socket for plugs that have been slightly uuumm F'ed with several times
The plugs in the sides of the heads sometimes are not 3/8' drive capable either. I found one that needed 8mm square. There is a KD socket set with these metric squares$$. Nothing a real good extractor with a 8mm tip couldnt get though
T.
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
