running hot after flush
Old Aug 16, 2005 | 02:24 PM
axehead's Avatar
my car was not running hot before, but is running hot after firestone flushed it. all the hoses have been replaced, bypassed the heater core, t-stat has been replaced with a 160, it has a pcmforless chip that turns the fans on earlier (i can hear the fan working), it has an electric water pump (i can hear it working & a performance shop checked it out-its fine), took it to the chevy dealership to make sure all the air is out-they claim there is no air in the system, it has distilled water with purple ice.
it doesn't run hot on the interstate or at idle with the ac on max in 90 degree weather, only during stop & go situations (city driving).
this is driving me crazy, does anyone have any ideads? radiator? HELP!
Old Aug 16, 2005 | 02:25 PM
blackztpi's Avatar
Re: running hot after flush
you probably have air in the system. keep bleeding it.
Old Aug 16, 2005 | 02:50 PM
axehead's Avatar
what is the correct procedure for bleeding? i took it to the chevy dealer for this & they say that there is no air in the system. i don't think that has a blown head gasket either, because there is not any water in the oil & it hasn't lost any power. is there a writeup on the correct procedure for bleeding?
Old Aug 16, 2005 | 03:25 PM
lt11997's Avatar
Here you go,
http://shbox.com/1/4th_gen_tech2.html#radflush
Old Aug 17, 2005 | 08:09 PM
axehead's Avatar
thank you sir :-)
Old Aug 17, 2005 | 08:46 PM
97WS6Pilot's Avatar
Squeeze one of your hoses when its hot and see if it is building pressure. If it doesnt build pressure the coolant will boil. My owners manual calls for GM sealer(prestone will do) whenever you change the coolant. Mine wouldn't build pressure till I put the sealer in.
calaban
May 18, 2020 06:43 PM
Sandersen511
Jan 13, 2015 03:49 PM
Collector Car
Dec 17, 2014 01:12 PM
CLEAR
Aug 30, 2002 07:49 PM
