how to get rid of clutch pedal squeek in a m6!
has anyone had and/or fixed this problem? it only seems to happen in the cold weather but it drives me nuts every time i shift. ive tried spraying wd40 but it doesnt seem to work. im also not exactly sure where its comming from. any help would be great
my squeak in my s-10 was coming from the rod sliding in and out of the bushing in the cylinder. try getting some lithium grease on it towards the firewall and it should help out. Mine didn't completely disappear till I changed it when I did a clutch swap.
good luck.
good luck.
