How to get to the CAI filter from below?
Old Sep 29, 2003 | 12:05 AM
Ace_437's Avatar
I was thinking about cleaning the filters of my SLP CAI and have read that it's easier to get to them from the bottom of the car. I climbed under while changing the fuel filter and didn't see any way to easily get to the filters. Unless I take of half of the nose it looks like I'll have to go through the top. How is it done?
Old Sep 29, 2003 | 12:12 AM
Steve0's Avatar
Re: How to get to the CAI filter from below?
Infront of the wheel well there is a plastic mudflap that you can disconnect. Disconnect it from teh wheel well all the way up to about halfway to the center of the nose and you should easily be able to reach into the wheel well and acess the filters.
Its a bit of a pain, good luck!
Old Sep 29, 2003 | 12:13 AM
LPEdave's Avatar
I assume the SLP filters are in the same place as the K&N one - the area just below where the stock filter is. You can remove just the triangular piece of the underbody there, about half a dozen screws. Pretty simple to do.
Dave
Old Sep 29, 2003 | 12:14 AM
Ace_437's Avatar
I guess I'll have to take another look tommorow then.
Old Sep 29, 2003 | 12:17 AM
Steve0's Avatar
The screws for teh mudflap go all teh way around the bottom edge of the car. It shouldnt be find to see at all. They connect the plastic flap to the body molding.
Old Sep 29, 2003 | 12:23 AM
Ace_437's Avatar
I saw a plastic panel, but It looked like I'd be taking of the bottom of the whole fron end. Am I looking at the right panel? If so, I guess I'll just take it off. The filters have been on for around 1500 miles now and probably need cleaned before being put away for winter.
Old Sep 29, 2003 | 12:25 AM
Steve0's Avatar
Yeah thats the panel. Its flexible so you dont need to disconnect the whole thing. Once you get it about halfway undone you can bend it to fit your arm into the space.
Old Sep 29, 2003 | 12:35 AM
kevkop94TA's Avatar
Thumbs up
You can also take off the driver side inner wheel well. It's like 6-8 screws, gotta jack it up and take off the front wheel too, the plastic comes out and the filter is right there. I just discovered this while I was pulling and painting my inner fender wells and figured since it was so easy I might as well pull the filter and clean it too. Looks awesome with the wells painted nice and shiny black.
Old Sep 29, 2003 | 04:19 AM
revtime's Avatar
They are a pain to take off and you get more air up there with them off.
Mine have been gone for years.
It takes a bit of wrenching on all those bolts but if you get up under the car its just time consuming more than anything.
Old Sep 29, 2003 | 07:37 AM
97LT1F-Body's Avatar
Exactly, I agree. Just remove the plastic and make life easier.
"work smarter, not harder"
Ive had mine removed and never had a problem with water, debris, etc. getting up there.
Mike
Old Sep 29, 2003 | 08:09 AM
markzman97's Avatar
I modified the metal area that the filter fits into so I could pull the whole thing from the top, it is way easier and I'm always sure the filter is attached securly.
Old Sep 29, 2003 | 08:41 AM
Nuke's Avatar
If your filters have only been on the car for 1500 miles, then you really don't need to clean them. If the filters are K&N filters, K&N recommends they only be cleaned every 50,000 miles. They filter better when they're dirty.
Old Sep 29, 2003 | 06:42 PM
Bud M's Avatar
You need to remove the air dam or at least lower it on the driver's side then you can remove the splash panel. To make future filter cleanings easy, you can make a removeable access panel and attach it to the bottom of the splash panel. That's what I did and filter maintenance is a snap.
Old Sep 29, 2003 | 07:24 PM
ThotYouKnew's Avatar
i think the screws are 10mm...atleast i think thats what i used when i tried to run DRL's on my 96...ha i wanted the bright amber look that i see on newer Zs and corvettes but i couldn't break anymore relays..ha $4-5 a piece...and i broke like 3 or 4...and gave up...
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
colts0455
Sep 11, 2015 06:16 PM
Sep 11, 2015 09:44 AM
tdigger9899
Sep 7, 2015 10:56 AM
