how to fix engine code po400
Old Feb 25, 2003 | 05:52 PM
red96z's Avatar
does this mean i need new egr?
Old Feb 25, 2003 | 06:15 PM
drop top steve's Avatar
Go to your local Chevy dealer and ask if you qualify for "special policy #00096, egr replacement" if your under 70,000 miles you should be.
Old Feb 25, 2003 | 06:21 PM
It means the pcm is not seeing enough change in MAP when the EGR is energized or de-energized. It could be the EGR valve is sticking or the vacuum diaphragm is not holding vacuum, bad vacuum line/leak...
Old Feb 26, 2003 | 09:15 AM
EviLBoX's Avatar
Cleaning the EGR or replacing it may fix the problem, but if not you're another victim of the "lack of enough backpressure to make the EGR function properly" in which the only real fix is to have the code programmed out. I've recently seen a post where someone made an EGR simulator though, but I haven't tried it. Do a search for "P0400" in this forum for more info.
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
MislMan
Jul 19, 2002 11:41 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
