how to fix engine code po400
It means the pcm is not seeing enough change in MAP when the EGR is energized or de-energized. It could be the EGR valve is sticking or the vacuum diaphragm is not holding vacuum, bad vacuum line/leak...
Cleaning the EGR or replacing it may fix the problem, but if not you're another victim of the "lack of enough backpressure to make the EGR function properly" in which the only real fix is to have the code programmed out. I've recently seen a post where someone made an EGR simulator though, but I haven't tried it. Do a search for "P0400" in this forum for more info.
Jul 4, 2005 05:00 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
