How fast can you safely spin stock internals?
I have a bone stock bottom end, stock valvetrain. How high can I safely spin my LT1? I wouldn't be doing it all the time, but just in case I need to pull a little higher at the top of 4th in the 1/4 mile. Plus I'd like to know my safety margin if I am shifting at 6000 RPM or so.
Find out exactly when your HP is made and I bet you never have to go above 5500-6000 rpm's Unless you have done a lot of head work on a stock bottom end.. If you go higher your endangering the car without gaining a thing.
Originally posted by Tony Danza
do you have the stock cam included in that "stock valvetrain"?
and how are you topping out your 4th gear in the 1/4? nitrous?..........did/do you mean 3rd gear?
ChrisFrez
Jan 11, 2015 03:47 PM
, I would say 6000 is as far as you would want to go safely. Above that your sort of taking a gamble.
