how far will crank hub slide on until it needs "persuasion"??
Old Jul 12, 2003 | 07:45 PM
Jesse_Boyer's Avatar
I was going to put my crank hub back on the new motor and it will only slide on about 1/2 inch before it starts to hang up. Does that sound about right?
Old Jul 12, 2003 | 07:56 PM
NOMAD's Avatar
Re: how far will crank hub slide on until it needs "persuasion"??
Yes, its a press fit. You usually barely need to put it on before it starts getting "hung". Trust me.. I've lost 2 now
-Shannon
Old Jul 12, 2003 | 08:09 PM
funina91ss's Avatar
I use all thread to install the hub on the crank. thread it in put a 13/16th 1/2" drive socket inside the crank hub and a nut you will have to keep the crank from turnning. I put a screw driver between the flywheel and starter... crank it down untill it is in the same place as before,you will see the clean line.
Boss002
Jan 20, 2016 12:17 PM
4586
Aug 18, 2015 07:08 AM
Boss002
Jul 24, 2015 10:47 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
Catmaigne
Jul 14, 2015 05:17 PM
