How far can you bore a stock Lt1 block?
Old Mar 17, 2006 | 10:27 AM
user 647483's Avatar
I read on a page today about a 350 LT1 block bored .100 over (409CID)
Can you really bore these blocks out that far?
I can understand that you probably couldn't go any further if you damaged the cylinder walls somewhere down the road, can you think of any other drawbacks to that kind of extreme displacement?
Old Mar 17, 2006 | 10:30 AM
LiENUS's Avatar
Re: How far can you bore a stock Lt1 block?
Cylinder wall flexing which robs you of power due to insufficient ring seal is the most immediate problem, the next one and most obvious is weakened cylinder walls which tend to crack if pushed too far. I've also heard that the thin walls can cause overheating problems, but don't know for sure on that.
Old Mar 17, 2006 | 10:31 AM
Javier97Z28's Avatar
Moderator
Read this thread for assloads of information on the subject:
http://web.camaross.com/forums/showthread.php?t=433631
Old Mar 17, 2006 | 10:35 AM
Great info! Thanks guys
I'll stick to 383 and 396 configurations with the stock block.
Unless some amazing aftermarket block falls off a truck in my front yard.
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
