how does this shortblock sound?
Old Oct 12, 2008 | 10:43 PM
jeremy stanke's Avatar
385 LT1 short block built by Kowalsky machine out of Lynchburg Va (www.kowalskymachine.com)
Scat forged 4340 crank 3.75 stroke
Eagle 5.7" H beams
JE forged pistons (12.5:1 w/64CC heads) 4.040"
SpeedPro hell fire rings
Program billet 4 bolt mains with ARP main studs
all coated bearings (std size)
Cloyes Hex-a-just double roller
Melling HVLP oil pump with welded on pickup for Milidon pan
machine work
4.040 bore and hone
line honed
true 4 bolt block
rings gapped for nitrous
0 decked
lifter valley holes tapped and filled with pipe plugs and vent tubes to prevent windage
front and rear drain plugs screened
Milidon 7qt oil pan
SFI damper (pro products)
COMP cams custom grind solid roller cam installed and degreed in
24X*/25X* 63X"/64X" ( the lift is with a 1.65 intake and 1.75 exhaust rocker)
motor was almost the same before the rebuild and made 562HP and 527TQ at 6700 with 11.5:1 compression on motor on the engine dyno but is built for up to a 300 shot
i think i will be going with either AI or LE heads
Old Oct 12, 2008 | 10:47 PM
mdacton's Avatar
That place is not far from me, never heard of them
Its near Sonny's
Old Oct 12, 2008 | 11:28 PM
cblinkdude182's Avatar
Wow mdacton didn't call you a ***** and say how slow you were... you must be doing something right
Old Oct 13, 2008 | 01:07 AM
MachinistOne's Avatar
Sounds fine except for the chinese junk pro products damper - ditch that for an ATI. Also I would be building some trick flow heads if you're spending that much money on the bottom end. Will flow more when ported, and thicker deck for nitrous use.
You also do not want a high volume pump, especially with a solid roller cam - just extra parasitic loss and excess oil in the top end. Get a standard pump with the high pressure spring.
Old Oct 13, 2008 | 07:45 AM
ok thanks for the tips, i actually didnt pay that much for it, i got the whole thing for 1700
Old Oct 13, 2008 | 08:47 AM
slomarao's Avatar
its a nice setup, swap in a ATI damper.
Old Oct 13, 2008 | 07:00 PM
sn8ke eatr's Avatar
kowalski?
Old Oct 14, 2008 | 10:09 AM
SS MPSTR's Avatar
12.5:1 w/ 64cc heads? Are these pistons domed?
Old Oct 14, 2008 | 12:52 PM
sorry i dont know, i was told that they were a nitrous dome
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
