How does this look for a RR setup??
Old Jul 31, 2004 | 06:48 PM
speed76demon's Avatar
Pr Magnum Comp Cams 1.6 7/16" stud, not self aligning, not self aligning use with screw-in studs and guide plates $298.00
Comp Cams 7/16" rocker stud set $41.95
Now I need help with the springs,guide plates and pushrods
Right now I am looking into ordering everything out of YearOne but I am considering calling up combination motorsports and ordering from them to see if they can put together something for me. What does everybody think??
Old Jul 31, 2004 | 06:51 PM
Spinner's Avatar
Re: How does this look for a RR setup??
I think you need to order them and get the studs and plates seperate. The only plate that fits right is the GMPP plate, which I doubt is included in that kit.
Old Jul 31, 2004 | 09:21 PM
TQdrivenws6's Avatar
Bingo, you need the GMPP guideplates. The LT1 has a valvespacing which differs by 0.050" when compared to a standard small block. The p/n for the GMPP guideplates is: 14011051
From Dal S. they were somewhere around $2 each.
Old Jul 31, 2004 | 09:29 PM
ibanez6rg's Avatar
Ditto on the guideplates. I got mine from Thunder Racing, I think.
Old Jul 31, 2004 | 10:51 PM
TxTransAm's Avatar
for springs, i reccomend the crane 10308 set. they come with springs and moly retainers/locks. plus they're probably the best double valvesprings you can get that you dont need to machine the heads for them to work.
Old Aug 1, 2004 | 10:45 AM
Bud M's Avatar
Stock cam? You can use LT4 valvesprings and stock pushrods.
Old Aug 1, 2004 | 11:08 AM
ibanez6rg's Avatar
He'll need hardened pushrods with guideplates. Some say they were in 94 and some say they weren't.
Old Aug 3, 2004 | 12:53 AM
Bud M's Avatar
I was under the impression that all 94s had hardened pushrods and the change came in 95.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
