How does the LE1 Idle?
Old Feb 16, 2005 | 07:09 PM
jchevy's Avatar
Anyone have this setup and can tell me first hand. LE's site says it idles like a hotcam or cc305. I have this package on order and have seen the specs of the cam and am just wondering if it really does idle like these other cams?
Old Feb 17, 2005 | 03:34 PM
jchevy's Avatar
Re: How does the LE1 Idle?
Bump
Old Feb 17, 2005 | 03:41 PM
Tony Danza's Avatar
The biggest factor for noticiable lope would be the LSA. Compare the LE's spec vs. other cams you've heard.
Old Feb 17, 2005 | 03:50 PM
marshall93z's Avatar
i dont see how someone could compare the HC and the CC305?? no comparison on the ones i have heard!
Old Feb 17, 2005 | 03:55 PM
jchevy's Avatar
really, the idles are that much different on the two? Their durations are only about 2* different. Maybe you heard one on a 112 and one on a 114 LSA or something.
Old Feb 17, 2005 | 03:59 PM
the cc305 IS on a 114...lol!
Old Feb 17, 2005 | 04:27 PM
DavesLT1's Avatar
isn't the hotcam a 112 LSA?
Old Feb 17, 2005 | 04:34 PM
jchevy's Avatar
I have heard of some hotcams ground on a 110
Old Feb 17, 2005 | 06:06 PM
jchevy's Avatar
Looking at the specs it seems to me that it will deffinatly have a chop to it, which isnt bad. But with it being a custom cam and all im not sure if for some reason it will be smooth.
Just looking for someone who has actually heard it.
Old Feb 17, 2005 | 07:35 PM
blue's Avatar
I have a slightly toned down version of the LE1 cam (mine's about 220/226) and his stage 1 heads. Through the stock cat, flowmaster, and manifolds it sounded pretty bad. So I assume the LE1 cam sounds more bad. Now I have LTs on with two high flow cats and it is a lot quieter.
Old Feb 17, 2005 | 08:04 PM
Munson's Avatar
Ill give you a sound clip in a week with le1 cam le2 heads, long tubes and borla XR1's through a 3" x pipe btw i have been on this board for a long time and have yet to hear an LE1 sound clip.. dunno why
Old Feb 17, 2005 | 09:08 PM
GreenDemon's Avatar
According to an e-mail I received from Lloyd the idle will be "slightly more radical" than a hotcam or a CC305. Remember that exhaust, tuning, and idle rpm can significantly effect how lopey a car sounds, in a lot of cases more than the cam itself.
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
