How do you reinstall lower timing chain sprocket?
Old Apr 10, 2005 | 03:03 PM
Beyonce Knowles's Avatar
I had to use a 3 jaw puller to get the original off, and I can't get the new one on. Do I temporarily reinstall the hub and hit it with a mallet to get the sproket seated right? Do I just hit the new sproket with a mallet? I lubed it up pretty good before sliding it on.
Old Apr 10, 2005 | 03:20 PM
Re: How do you reinstall lower timing chain sprocket?
Okay, I just found this on shoebox's site, but what is that "tool" on the right? Could I use PVC?
Old Apr 10, 2005 | 03:23 PM
sssalah's Avatar
You can use a short pipe and hit it with a hammer, it's fairly easy to fix. The hub is interference fit and it would be more difficult to put and remove.
Old Apr 10, 2005 | 04:18 PM
RamAir95TA's Avatar
You could try and use PVC, but I'm sure it would break far before you got the sprocket seated.
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
