How do you put in a CTS?
Old Apr 18, 2007 | 04:05 PM
Loony's Avatar
My car needs a new coolant temp sensor. Do I have to drain some coolant out and then put it in or what. I don't want coolant all over my driveway. What should I do? Thanks!
Old Apr 18, 2007 | 04:19 PM
ricehammer's Avatar
The one in the water pump or the one for the temp gauge in the driver side head? The sensor in the water pump is easy. Teflon tape the threads on the new sensor, throw a couple cloth towels under your car, unscrew the old sensor and quickly put the new one in. Takes 2 hands, one to unscrew the old sensor and the other to place the new one in. I did it this way and lost less than 8oz fluid. Gotta be quick though.
Loony's Avatar
The one in the head.
Old Apr 18, 2007 | 05:24 PM
97 LT1formula's Avatar
your gonna have to drain most of the coolant out to change that. After the coolant's out its easy
Old Apr 18, 2007 | 05:37 PM
2000GTP's Avatar
Just put a catch pan under it, it isn't going to spill out that much coolant from the head. After you replace it, just put the coolant back in and call it a day.
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 4, 2015 08:43 AM
mark0006
Dec 25, 2014 09:50 PM
guionM
32
Aug 19, 2002 01:39 PM
jrp4uc
12
Jun 26, 2002 01:57 AM
