How do you prime your new LT1 before startup ??
Old Mar 30, 2006 | 02:02 PM
MAJESTIC's Avatar
I have had a Lt1 sitting for almost a year, I will install it again in a few weeks
and would like to know how in the world do you prime these LT1's before startup. ??
(prime with oil)
Old Mar 30, 2006 | 02:15 PM
z96's Avatar
z96
Re: How do you prime your new LT1 before startup ??
remove coil wire and crank with starter
Old Mar 30, 2006 | 02:34 PM
MAJESTIC's Avatar
Are you being for real????
I thought turning your starter for more that 10 seconds was not a good thing?
Or doing it over and over, will burn up the starter.
Old Mar 30, 2006 | 02:38 PM
Silvershark's Avatar
Thats how I primed mine. I havent had any starter problems... It's been a year later.
Old Mar 30, 2006 | 02:46 PM
MAJESTIC's Avatar
How long did you let your starter spin for??
Old Mar 30, 2006 | 02:51 PM
I just cranked it for about 2 seconds each time i turned the key. I turned the key 5 times.
ibanez6rg's Avatar
Take a drill and use it to turn the shaft connected to the oil pump.
Old Mar 30, 2006 | 03:17 PM
MAJESTIC's Avatar
Thats how I do the carbed motors. I was just not sure if there was not another way for the LT1.
Old Mar 30, 2006 | 03:25 PM
fastchevy's Avatar
Hell, that defeats the whole purpose of priming it...might as well fire the thing up.
Old Mar 30, 2006 | 04:48 PM
1racerdude's Avatar
Remove the intake and get a priming tool and prime it with a drill. Ya don't know what kind or how much assy lube is on the bearings.
To give ya an idea how ctitical it is Cup teams only turn the engine 3 rev for a complete assy including valve adjustment.
If it's a used engine then it would be like it setting in storage for a year,just crank and go.
Old Mar 30, 2006 | 11:59 PM
TransAm396's Avatar
i did the same thing.turned it over for 10 seconds...never had a problem with my starter.
guionM
69
Nov 30, 2006 02:01 PM
Lions3
Apr 11, 2003 10:55 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
87formula350
Aug 19, 2001 01:02 PM
