how do you get to the rear main seal?
Old Nov 11, 2004 | 11:03 AM
fstenuf's Avatar
i get a lot of smoke through my shift boot that smells like burning oil. it only happens at high revs, so i'm guessing its the rear main seal. just wondering if i need to have the motor pulled? i'm having my tranny gone through this spring so if i could fix the rear seal with the tranny out that would be cool if not then i guess they'll both have to come out. thanks for your help!
Old Nov 11, 2004 | 11:06 AM
Z95m6's Avatar
Re: how do you get to the rear main seal?
you can replace the seal when the tranny is out.
Old Nov 11, 2004 | 11:22 AM
fstenuf's Avatar
perfect. where can i get one of those seals and how much do they cost?
thanks
Old Nov 11, 2004 | 11:31 AM
izzyz28's Avatar
Any auto parts store will have the seal, and it's probably around $15 or so. Before you change it though you may want to take a closer look and see where the oil is really coming from. I would suspect a valve-cover gasket before a rear main seal. Get under the car with a good flashlight and follow the oil slick to the source.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
BigWil
Mar 29, 2015 12:24 PM
carl.froehlich
Mar 13, 2015 12:38 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
