How do you get the motor mount housing apart?
Old Jul 18, 2005 | 05:03 PM
Valkyn71's Avatar
Just dropped my K-member and my stock motor mounts are sagging an increadible ammount.
How do you get them out of the "shell" that they are in? Do you just put a screw driver inbetween the pieces and pry them apart or whats the trick?
Old Jul 18, 2005 | 05:08 PM
turbo_Z's Avatar
Re: How do you get the motor mount housing apart?
You have to drill out those rivets.
Old Jul 18, 2005 | 05:13 PM
Valkyn71's Avatar
Ahh thought it was really suck together good
Any recommendations on which mounts i should get? Either Prothane or Energy suspension.
Old Jul 18, 2005 | 05:15 PM
turbo_Z's Avatar
I have the prothane no complaints. Never have held a ES mount to compare them.
Old Jul 18, 2005 | 06:07 PM
CamaroBoy96Z28's Avatar
Same here. Prothane has treated me well so far.
Old Jul 18, 2005 | 09:19 PM
matt65's Avatar
I have the Prothanes. Good looking parts. I have not intalled them yet. Upcoming Header install.
Old Jul 18, 2005 | 09:44 PM
Valkyn71's Avatar
I got the energy suspension ones.
Between those, my ES tranny mount and my new tubular K-member and A-arms with spherical rod ends my car should be plenty noisy.
Old Jul 18, 2005 | 09:45 PM
Silvershark's Avatar
I have the proeurethanes. They are great mounts, just make sure you get the stock style tranny mount or you will get some bad vibration. Get a drill and a drill bit and drill them out. Then use a nut and a bolt to bolt them back together.
Old Jul 18, 2005 | 09:51 PM
jchevy's Avatar
I have heard that you either want to run all rubber, or all poly mounts. Mixing the two can cause vibration. I dont know, just what i have heard.
I run poly motor, tranny and tq arm mounts in my car. Vibrations arent bad at all.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
CaRParts102
Dec 6, 2014 08:45 AM
Nostang 96z
Aug 31, 2002 12:01 PM
