How do you fix an erratic idle
Old Jul 30, 2004 | 04:30 PM
89coupe's Avatar
I have replaced the ICM which made the symptoms better, but not totally gone. If I sit at a light I can watch the idle bounce up and down, the car also surges a little. The longer the car is at idle the worse it gets. At first the idle will jump around from 900 to 1,050 and then in time it will be 500 to 900. If I use the AC the will not idle w/o giving it gas. I don't think there is a vacuum leak because the intake was just taken off to install new pushrods and lifters. My great G2 cold air kit does not fit snug with the stock airbox, could that cause it? I don't know what to look for next? Thanks for the help!!
Mark
Old Jul 30, 2004 | 04:49 PM
amean94ta's Avatar
Re: How do you fix an erratic idle
i need to know also so here is a ttt
Old Jul 31, 2004 | 10:41 AM
89coupe's Avatar
anybody? this is really hard to figure out. I used the a/c yesterday and I could not keep the care running at a light. Please help!!
Old Jul 31, 2004 | 10:53 AM
JDBlaze85's Avatar
can u get a data scan on your car? see what the IAC counts are? what year is car?
Old Jul 31, 2004 | 06:46 PM
89coupe's Avatar
I had it data scanned, but I don't have any of the info. with me. My car is a 93, but it has been converted to mas-air. I have a LT4 hotcam, ported heads and SLP headers to name a few things.
I tried checking for vacuum leaks by spraying brake cleaner, but I could not find anything. This really sucks.
Old Jul 31, 2004 | 07:30 PM
95WhiteTA's Avatar
could be your IAC or clogged injectors, if you're sure its not missfire.
Old Jul 31, 2004 | 09:49 PM
89coupe's Avatar
new IAC and all injectors were cleaned about a week ago.
Old Jul 31, 2004 | 11:21 PM
JDBlaze85's Avatar
find out what the map and the iac counts are
Old Jul 31, 2004 | 11:46 PM
95WhiteTA's Avatar
make sure you dont have a vacuum leak, an lt1 z28 i had did that and i had a vacuum leak.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
andrewcapps82
May 19, 2015 10:11 PM
Fatdog2
Feb 13, 2015 08:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
MislMan
Jul 19, 2002 11:41 AM
