whats a flashing ses light mean?
Old Jul 31, 2004 | 12:27 PM
clownhair's Avatar
When I drive my car around every once in a while the ses light flashes, what does that mean?
Old Jul 31, 2004 | 12:39 PM
94Zpower's Avatar
Re: whats a flashing ses light mean?
probably an intermtent problem like a loose wire or something that gets moved around abit when hitting a bump in the road or something but only a scan will tell you for sure.
Old Jul 31, 2004 | 12:55 PM
SS MPSTR's Avatar
Likely a misfire detection.
Old Jul 31, 2004 | 03:01 PM
Flashing usually indicates an issue that should be immediately addressed. Commonly, a misfire that is causing too much fuel to be sent downstream to the cats. If not corrected, cat damage can result.
Old Jul 31, 2004 | 04:23 PM
slayer6x6's Avatar
DANGER TO CATALYST
Old Jul 31, 2004 | 04:24 PM
slayer6x6's Avatar
.......OBD2 that is
Old Jul 31, 2004 | 10:22 PM
Heatmaker's Avatar
Advanced Member
A FLASHING SES LIGHT!!!!!!!!!!!
And you still drive your car?
As sensitive as the SES light is "goes on if a light bulb is out"
I'd be on the First Tow truck to the GM dealer!!!!
Old Aug 1, 2004 | 12:00 AM
kingman109's Avatar
well - i have a 97 and it was wrecked and rebuilt completely - my SES light is on all time becuase of my skip shift eliminated (previous owner didnt do properly and i pan on fixing this week cause dont like light to be on and not know if something else) anyway i have a code scanner and every now and then my SES light will flash -
i scanned codes and my code was a misfire- changed plugs and wires turned out 4 and 8 were shot (plugs) since then no problems... light flashed yesterday ... scan... now O2 sensor is shot... will change this week and see whats up..
bring car to like autozone or something and have codes read- prob misfire or o2 sensor
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Rodrigues
Aug 24, 2002 01:46 PM
Z28Wilson
Aug 1, 2002 04:27 PM
