How do you disable 97 stock alarm system, car will not start
Old 11-17-2009, 05:30 PM
playa7970's Avatar
just curious if anyone knows because my alarm keeps going off and i can start my car at all thanks is there a way to disable the system completely
playa7970 is offline
Old 11-17-2009, 06:27 PM
Did 94s have alarms? Perhaps dealer installed or aftermarket? If you mean the VATS system, you can find info on my website.
http://shbox.com/1/pass_key.html
shoebox is offline
Old 11-17-2009, 06:46 PM
bkpliskin's Avatar
VATS =
I hate it... always gives me the 'security' light and makes me wait 3 minutes to start my car. I'm disabling every aspect of the system this winter. It makes it harder for me to start my car than it would for a potential car theif.
bkpliskin is offline
Old 11-17-2009, 07:59 PM
playa7970's Avatar
thank you for the quick reply as always shoebox, i am talking about VATS on a 97 camaro (its my friends) if he would buy a new factory keypad from GM will that take care of his issues? (he lost his factory keypad) if not is there a way around this system? thank you again here is what he did so far...
1. used two different keys then waited 3 minutes for the alarm to turn off but... the security light kept flashing and we were not able to start the vehicle
Old 11-17-2009, 08:52 PM
Sorry, I ended up looking at your sig for the year.
I don't think the fob is going to have anything to do with the security light staying on. The mosts common problem is it not reading the key pellet.
shoebox is offline
Old 11-17-2009, 11:58 PM
playa7970's Avatar
thanks buddy im going to try the resistor trick on your site , is it just one wire that i am tapping into? thanks showbox your the best!
Old 11-18-2009, 06:43 AM
Two wires and a resistor. The site has the info.
shoebox is offline
Old 11-18-2009, 01:41 PM
playa7970's Avatar
thank you shoebox i got the car running with your resistor method very helpful thank you
Old 11-18-2009, 02:16 PM
shoebox is offline
Old 02-23-2016, 05:18 PM
FRIDAY_131984's Avatar
Re: How do you disable 97 stock alarm system, car will not start
Originally Posted by shoebox
I am having a no start issue on a 1997 camaro Rs the guy I bought the car from said that one day and acted like it was running out of gas then died. so he replaced the fuel pump fuel filter and fuel lines the car with them not start. he sold me the car for $200. As he could not figure out the no start issue. Since buying the car I have replaced the cold packs plugs wires ignition control module lock and key cylinder with key from GM starter CKS the sensor next to the CKS, oil pump sending unit sensor reset the cpu back to factory settings and i am not getting any fire to coil packs, to the cks or the fuel injectors. And not for sure where else to look. I think its my faults system due to when i put my horn fuse in the horn continues to go off. Where do i need to look at and please provide location for what you sugest as im dumb when it comes to these camaro rs models.
FRIDAY_131984 is offline
Old 02-23-2016, 08:36 PM
Small problem.... you posted in a thread on the LT1(V8) forum, so not necessarily a lot of V6 owners are going to read this. And these engines have major differences.
To start, at any time has the PCM been scanned for codes?
When you turn the key to "start" does the starter engage and crank the engine? When you do this, is the "SECURITY" light flash? Does it stay on solid?
Injuneer is offline
Old 02-24-2016, 05:09 AM
My starter engages my car cranks over but no spark. No security lights are on.
Old 02-24-2016, 03:15 PM
At any time has the computer been scanned for codes? Have you checked the fuel pressure?
How did you "reset the pcu (PCM) back to factory settings"? Do you mean you pulled the "PCM BAT" fuse for 30 seconds?
Injuneer is offline
Old 02-26-2016, 07:56 AM
Yes no codes came up fule pressure is fine and i reset the pcu by bumping car over leaving key on for 10 mins cut off for 10 sec then repeating two more times for a total of 30 mins and 30 sec
TheGreenZ28
Exhaust System
12-06-2014 10:23 PM
USAirman93
11-24-2014 03:37 PM
BIGCOWL-IMP
11-21-2014 09:40 AM
Brian-94TA
07-31-2002 02:52 PM
jwright3SS
07-30-2002 03:49 PM
Quick Reply: How do you disable 97 stock alarm system, car will not start
