How do you delete air pump
Old Mar 9, 2007 | 10:33 PM
jclark311's Avatar
Just like it says, i want to delete it, i just bought non emmisions headers?
Old Mar 9, 2007 | 10:48 PM
LiENUS's Avatar
If your car is 93-95 then just remove the pump and leave a fuse in, thats it. 96-97 need a tune I believe, of course... you could leave the pump on with 96-97 leave it plugged in just not hooked up to anything
Old Mar 10, 2007 | 02:11 AM
solarofthesix
Guest
Posts: n/a
What i did is bought an EGR Blockoff Plate and Header Tube Block Off from Ebay and took it all off at one time then I got a tune to remove the SES light.
Old Mar 10, 2007 | 02:59 AM
LiENUS's Avatar
He's deleting the air pump with non emissions headers. I just remembered I forgot to tell you you need a bypass plug cap for the intake. Autozone sells a bypass plug cap assortment pack in their help section that has one that fits.
Old Mar 10, 2007 | 03:27 AM
solarofthesix
Guest
Posts: n/a
oh i ddindt read that non header part....so i would recoment hitting ebay and getting the egr blockoff plate and some of those vaccume block offs for the intake manifold and remove all that crapola! I used shoebox's site to see what I could remove
Old Mar 10, 2007 | 09:49 AM
97formulakid's Avatar
Took it all off when I did the headers. Since I was already getting a tune I had him tune out the EGR and AIR. EGR blockoff plates can be had off ebay for 10 dollars. Air pump: take off all the pump and brackets and follow all the vacuum lines up to the intake and take them all off. Make sure to cap off any open ports that are showing off the intake.
Old Mar 10, 2007 | 12:55 PM
jclark311's Avatar
What about the belt, wont i need a smaller one? I already bought the Ebay block off plates.
Old Mar 10, 2007 | 02:48 PM
LiENUS's Avatar
What year is your car and where are you located?
Old Mar 10, 2007 | 02:56 PM
2000GTP's Avatar
A signature with some basic info and year of your car would be helpful. The air pumps on the 4th gens are electrically driven so there is no effect on the length of the serpentine belt. On the 3rd gens, however, the air pump was mechanically driven by the serpentine belt. Maybe you have the two confused?
Old Mar 10, 2007 | 05:27 PM
jclark311's Avatar
Yea i gotta get that signature thing going, the car is a 97 ws-6 Formula firebird, i am going with an LE2 setup, no emissions, computer was tuned by pcm for less, i am waiting on some parts, the car is being stored at a relatives garage for the winter, so i couldnt go out and take a look at it. IM posted to see what advice i could get before i start.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
cmdeshon
Dec 27, 2014 10:06 AM
