gold race series rockers
Old Feb 27, 2007 | 06:19 PM
lt1chevelle's Avatar
i bought 1.6 self aligning roller rockers for my motor that has le2 heads and 847 cam will they work ok? iam asking becuase i see alot of ppl going with non self alining rockers whats the pros and cons?
Old Feb 27, 2007 | 07:08 PM
2000GTP's Avatar
With that type of head/cam combo, it is recommended that you use a NSA rocker and guideplate setup.
Old Feb 27, 2007 | 08:00 PM
96ZCamaro's Avatar
Idk man. Because I have the self aligning ones. I rev my motor out to almost 7k and still works fine. Although I do only have 2k miles or so on the motor. So take it as you will.
Old Feb 27, 2007 | 08:23 PM
Projectz28's Avatar
Moderator
depends on you spring, valve and lock combo. most guys go NSA because they are running a +.050 lock and keeper to get more installed height for the bigger lift. In the end they end up with a fitment problem with SA rockers and the keepers.
Old Mar 10, 2007 | 05:29 PM
sorry i forgot all about my post the head are le2 and the cam is a gm847.
oldschool
Feb 9, 2016 09:21 PM
May 1, 2015 01:14 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Elcojoe
Nov 17, 2014 10:27 PM
