How do you compress the rear calipers???
Old Mar 23, 2004 | 07:49 PM
Black94mula's Avatar
I have never figured this out and I need too. I bought a tool today that a buddy at Carquest told me I needed. Its a square box with little nubs on it, supposed to spin the piston in as it compresses. But I don't see how its supposed to work on this caliper. Anyone got ideas?
Old Mar 23, 2004 | 08:01 PM
961le's Avatar
same as the front. 6in. clamp. one side against outer pad the other against the back of the caliper.
Old Mar 23, 2004 | 08:02 PM
Red96Lt1's Avatar
I always use a c-clamp.
Old Mar 23, 2004 | 08:05 PM
See I've done that and it doesn't compress enough. I've always left one worn pad in there and put one new one in to fit. I thought it had something to do with the parking brake or something.
Old Mar 23, 2004 | 08:09 PM
LimitedEd1LE's Avatar
I have always used a c-clamp and a big socket. Just put the socket on the piston caliper and then clamp the c-clamp down slowly until it no longer moves.
961le's Avatar
yeah, unhook the p-brake cables. that'll do it. i also did the "free travel" adjustment. after rear brakes i had no emergency brake engagement at all.
Old Mar 23, 2004 | 08:23 PM
DZNUTTS's Avatar
That's just the info. that I was looking for . .................
Old Mar 23, 2004 | 09:53 PM
Get your money back on the tool. Not needed.
Old Mar 23, 2004 | 10:07 PM
DZNUTTS's Avatar
Why? How do you do it?
Old Mar 23, 2004 | 10:33 PM
Well, I won't be able to tell until I get new pads tomorrow, but I unhooked the parking brake cable and compressed as much as I could. That also means I'll have to put some slack in the parking cable line behind the tranny right? Makes sense.
Old Mar 24, 2004 | 10:41 AM
HungryT/A's Avatar
Shoebox is right, no need for the tool. You can always compress them with your hands, pushing the piston back.
You gotta be patient, cause it's a hydraulic piston and you can't push it too fast, it takes a while, but it really takes no big effort to push on it. Just push that SOB and be patient
Old Mar 24, 2004 | 06:39 PM
joecool72's Avatar
DON'T FORGET TO UNCAP THE BRAKE FLUID RESERVOIR!!!
Old Mar 24, 2004 | 07:35 PM
961le's Avatar
i have a helm manual. go to shoebox site. look under free travel adjustment. it is the same info i have.
Old Mar 25, 2004 | 02:31 PM
Right, forgot about that, thanks alot guys.
carguy0119
Apr 11, 2016 11:11 PM
Alien
Jun 27, 2015 01:13 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
Z-rated97
Mar 29, 2015 11:17 PM
FirebirdGT
Dec 13, 2014 10:25 PM
