How do you calculate Gross Valve Lift, using different ratio rocker arms?
Cam card shows .571in .583ex, Iam using 1.5 on the intake side 1.6 on the exhaust. What is the gross valve lift using the rocker arms? Thanks
divide your valve lift by 1.5 and than multiply it by 1.6. In your example you would take your intake (571) divide it by 1.5 and get 380.6, than multiply it by 1.6 and you get your new lift (609) Hope this helps, prorac1
Brandon Wittmer
Dec 7, 2014 12:15 PM
