How do you adjust timing?
Old Oct 25, 2003 | 11:36 PM
jasons93z's Avatar
It Might be a stupid question, but i was just wondering. How do u advance the timing?
Old Oct 25, 2003 | 11:38 PM
Via tables in the computer. There is no way to externally adjust the timing.
Old Oct 25, 2003 | 11:43 PM
jasons93z's Avatar
si u have to send the pcm to like pcm4less. BTW, how are you guys impressed with pvm4less on a near stock engine. How long does it take to get back and where are they located.
Old Oct 26, 2003 | 06:02 AM
rskrause's Avatar
Moderator
From what I have seen on the dyno, there is very little hp to be gained from changing the calibration on a stock motor. Reprogramming may still be useful - to remove the speed limiter, change the rev limiter, adjust shift points, compensate for tire diameter, etc. But there is little hp to be gained. Maybe 5rwhp or so due to the stock calibration being a little bit on the rich side.
There may be considerable gain from turning off the knock sensor based retard. Many cars have false knock, especially if headers or noisier valve train components have been installed. The chance of enigne damage is there, but if you always use high octane fuel and use some sense about driving the car, there is unlikely to be a problem.
But in general, unless you are trying to fix a specific problem, a generic "tune" will be a waste.
Rich Krause
Old Oct 26, 2003 | 06:55 AM
jasons93z's Avatar
i think i might just get an lt4 knock sensor. I show a tiny bit(TINY) of knock if i dont use high octane. That should take care of it.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
jb4xx
Feb 2, 2015 10:00 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
