How do you adjust pushrod guide plates?
Old Jul 17, 2005 | 08:47 PM
crazypurgatory's Avatar
Question How do you adjust pushrod guide plates?
I would like to know how to adjust the guide plates on my race engine.
It's a Chevy 350 of course.
I have never used guide plates before and don't know how to adjust them.
I would guess you adjust them before you adjust the vlaves.
Thanks,
Chris G.
Old Jul 17, 2005 | 09:00 PM
Re: How do you adjust pushrod guide plates?
Did you buy adjustable guideplates? If not, the only adjustment by the amount of slack in the mounting holes and it isn't much. The amount of adjustment is gauged by observing the contatct pattern the rocker arm makes on the top of the valve stem.
Old Jul 17, 2005 | 09:09 PM
Question Re: How do you adjust pushrod guide plates?
They are ARF 220cc heads they came with there own guide plates.
With the studs loose they have a bit of play.
Thanks,
Chris G.
Old Jul 17, 2005 | 11:07 PM
Dan Parker '96's Avatar
I'm interested in the response as well.
But if there is no definite procedure then I believe my instinct is to "eyeball" it.
Do a couple "mock" assemblies and see if you achieve linear actuation without obstruction.
Normally, excessive rubbing of the pushrod is a good thing. But in engine assembly I think we would want to avoid it.
Old Jul 17, 2005 | 11:18 PM
You paint the top of the valve stem with machinists dye (or just use a Sharpie). Observe the wear pattern the rocker tip makes and adjust for best centering.
Quickss96
Jan 29, 2016 05:56 PM
Nutty's96
Dec 21, 2015 06:25 AM
Slayer
Aug 17, 2015 03:55 PM
karpetcm
Aug 14, 2015 03:02 PM
realistyc
Jul 28, 2015 07:32 PM
