how do these heads look?
Old May 26, 2005 | 03:42 PM
tkiely05's Avatar
im installing a cam soon and dont know much about heads how does this info look?
Heres a fresh set of Small Block Chevy aluminum LT1 high performance cylinder heads,casting # 10128374. These heads have 53cc combustion chambers. The heads were just freshly machined on a Sunnen cylinder head machine. H.P valve job, clean up milled surface,performance springs 115Lbs. seat pressure,290 open pressure, will handle .550 lift, premium valve stem seals and fully ported intake&exhaust bowls&short turn radius. New stainless steel valves 1.94Intake,1.5 Exhaust with undercut stems for more flow. These heads are an easy 30-40 Hp bolt on increase with the porting work and undercut stem valves. This vortec style port is a very good proven design even in its stock form but with the improvements done to these heads be ready to feel some increased power for your SBC !!
Old May 26, 2005 | 06:31 PM
SVThuh's Avatar
Re: how do these heads look?
How much? If I were you, I would pick up a set of untouched stockers from a 92-95LT1 and send them to Lloyd Elliot for a good port job.. Best bang for the buck there!
Old May 26, 2005 | 08:24 PM
RE AND CHERYL's Avatar
No matter what they say was done. Unless they have flow numbers, I wouldn't buy them.
Old May 26, 2005 | 08:47 PM
SSRZ28's Avatar
are those from that guy on ebay with the performance shop susposedly. if it is, i think his flow numbers were lke 240? i would go with the LE heads
Old May 27, 2005 | 01:47 AM
SVThuh's Avatar
LE heads own most of the others that you will come across.. Esp for the money, the power gains cannot be beat.
Old May 27, 2005 | 10:07 PM
Quickshotkimber's Avatar
For the SAME money, They CAN be, and HAVE been.
Old May 27, 2005 | 10:12 PM
My heads only flowed 248 with stock size valves. All these LE guys should be blowing my doors off
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
