How do these corrected times sound?
Old Aug 24, 2003 | 08:37 PM
  #16
thewinner's Avatar
Can i take teh 0 DA times and multiply them by these correction factors to get the altitude times?
http://www.nhra.com/2002/sportsman/n...ry/021501.html
10.73@120.29 0 DA. at 2000 ft would be 10.97@117.62
who knows....
Old Aug 24, 2003 | 11:57 PM
  #17
atljar's Avatar
Originally posted by thewinner
Ya, im not really putting any money into the 10 bolt, rather saving money for a 12bolt and dealing with what i have. But soon i am going to get a strange, cause i can get some good deals on new ones. Planning on 4.11s and ET streets, what size ET streets will fit 16" wheels? or do they only have one 16" size? Wonder what the gears will do to my shifting, since im going through the finish at the top of 3rd gear?
But, if i find a place with a close to zero DA it theoretically should run 10s?
You say mph is skewed b/c of spinning launch, should it be higher or lower?
ET streets come in many different sizes that fit on 16 inch rims. Wider, skinnier, taller, shorter. Thats a totally new and different thread however.
410s will put you pretty far into 4th gear. I have 4.33s and am trapping in 4th at about 6400rpm.
AS for what it will run, i say the best you will get out of it anywhere, anyplace, is 11.4-11.5.
AS for spinning on the launch, the more you spin, the higher you trap, but the worse the ET. The harder the car hooks, the lower the trap but the better ET
Old Aug 25, 2003 | 12:15 AM
  #18
97bowtie's Avatar
Wrong.
Old Aug 25, 2003 | 12:25 AM
  #19
atljar's Avatar
No, right. To a certain expent you want a tad of wheel spin (John lingenfelter says 10%) for optimal ET, but if you spin you will trap higher than if you hook. Guess you have never run sticky tires eh?
Old Aug 25, 2003 | 12:30 AM
  #20
97bowtie's Avatar
I run ET Streets everytime out to the track.
eh?
I have ALWAYS trapped higher running on ET Streets than on street tires.
That is a flawed theory.
Old Aug 25, 2003 | 12:41 AM
  #21
97bowtie's Avatar
I know there are certain cases where spinning has yielded higher trap speeds, but it is a rarity in the real world.
I have consistently trapped 1-2 mph higher running on ET Streets (13-14 PSI) than on street tires.
Cutting a better 60' means you are leaving harder and in turn accelerating faster - somewhat of a slingshot effect.
People will argue that spinning allots you more time to accelerate because your ET will be slower - that is NOT true IMO...the distance being covered is the same regardless of how much you spin or hook, but hooking makes the car accelerate harder/faster, increasing your speed through the traps.
From my personaly experience, as well as many of my friends' experiences, hooking increases mph.
Old Aug 25, 2003 | 12:55 AM
  #22
atljar's Avatar
At least you have some data to back up your point, and i respect your real world experience. I on the other hand have the exact opposite experience. I run Nitto DR as a street tire, and 26" ET streets for slicks. I know there is a SLIGHT gearing difference between the tires, but i consitently will be a few mph slower on the ET streets, but also a few tenths faster.
Old Aug 25, 2003 | 01:09 AM
  #23
97bowtie's Avatar
Yeah - I've seen it go both ways, just seems to go the other way more often than not. What happens to your 1/8 mph with the ET Streets compared to the DRs?
  #24
thewinner's Avatar
do these 26" Et streets fit on 16" wheels? if not what brand of 15" wheels fit best?
Old Aug 25, 2003 | 01:35 AM
  #25
atljar's Avatar
Yes you can get the 26" tires to fit 16" rims.
Bowtie-
I have to go back and dig up some timeslips from last year where i ran both tires on the same day to see some 1/8 mile stuff. With the new set up i only have 1 pass on the DR, and it was on a totally different day than the ET street times with different weather paterns etc, but these slips show a little of both our points. Also shift points are no where near consistent yet with the cam, still feeling it out. Like i said, will try to find some of last years slips
drag radial (70ş, low humidity, low DA)
60 = 1.950
1/8 = 8.377
mph = 87.59
1/4 = 12.861
mph = 113.86
ET streets (83ş, humid, really high DA)
60 = 1.988
1/8 = 8.358
mph = 87.94
1/4 = 12.885
mph = 109.78
ET streets (83ş, humid, really high DA) (same day as above)
60 = 1.904
1/8 = 8.331
mph = 85.10
1/4 = 12.856
mph = 106.95
Old Aug 25, 2003 | 02:29 PM
  #26
97bowtie's Avatar
It looks like there are other things going on there besides the tires, namely the temperature and humidity. Humidity will kill trap speeds. Looks like your car is running pretty well.
Old Aug 25, 2003 | 04:06 PM
  #27
atljar's Avatar
Yes i tried to point out about the weather, that plays a HUGE factor in the times. Also those were all shifted at different rpms etc, waiting on the shift light in the mail to nail it down and get something consistent. Also need to work on the launch. Launching a cammed car is a totally new ballgame from last year exhaust/gears car (1.7 60's)
Old Aug 25, 2003 | 06:20 PM
  #28
thewinner's Avatar
Gotta get on a dyno.....
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Collector Car
Jan 5, 2015 10:58 AM
Lions3
Aug 27, 2002 01:33 PM
Bando
Aug 2, 2002 02:18 PM
