How do our motors relieve internal pressure?
Old Aug 28, 2004 | 10:53 AM
F(ast)-body's Avatar
Had an "old school" hotrodder wanting my airpump that I removed from my car for his drag car because he said he can use the pump to relieve the internal pressure that builds up in his engine. Then he asked what our engines did to relieve internal crankcase pressure and frankly, I had no answer for him. Does anyone know?
Old Aug 28, 2004 | 11:20 AM
ScrmngChckn95's Avatar
Re: How do our motors relieve internal pressure?
I believe the Positive Crankcase Ventilation (PCV) system does this for us. Though I'm not quite sure how it works.
Old Aug 28, 2004 | 01:19 PM
Terran2k's Avatar
yeah i believe its the pcv
Old Aug 28, 2004 | 02:01 PM
96capricemgr's Avatar
Every street car I have ever worked on used a PCV valve, basically it uses manifold vacuum to suck the bad gasses out of the crankcase.
Old Aug 28, 2004 | 02:55 PM
)2overt SS's Avatar
Thats pretty much it... Chiltons learned me that
Old Aug 28, 2004 | 03:02 PM
sssalah's Avatar
I wonder if that small pump is going to get the job done for him. This pump is used for pushing a small amount of air, and what he needs is a vacuum pump.
Old Aug 28, 2004 | 03:04 PM
96speed's Avatar
It will not pull enough vacuum. It has been tried (more than once) without success.
Ryan
Old Aug 28, 2004 | 03:12 PM
SSnakeEater's Avatar
well, not "bad gasses", just gas in general.
HydroCarbons to be exact
Old Aug 28, 2004 | 03:36 PM
n2ceptor's Avatar
crankcase evacuation system
Old Aug 28, 2004 | 04:02 PM
jdizzell's Avatar
Your "old school hot rodder" should read up on some of the new school because the AIR pump is not a vacuum. It is a pump that pumps air into the exhaust to dilute it buring cold starts to keep your cats working.
Old Aug 29, 2004 | 10:55 AM
Some "off" info here.....
And water vapor... a product of combustion/blowby. Let that condense in your oil and see what forms.
...the AIR pump is not a vacuum. It is a pump that pumps air into the exhaust to dilute it buring cold starts to keep your cats working.
But its a common trick to attach the SUCTION side of the AIR pump to the PCV valve location, and let it "vacuum" the gasses out of the crankcase, and dump them into the exhaust. Unfortunately, it is not capable of developing more than about 5"Hg vacuum, but it is vacuum.
LeftoverChinese
Jan 14, 2024 03:03 PM
transam_388
Mar 15, 2015 11:53 AM
armedtrigger
Feb 24, 2015 08:30 PM
