How do I tell if I have a Bad Head Gasket/Intake man. leak?
Old Jun 13, 2007 | 07:58 AM
lt1car's Avatar
I got the water pump off to change the opti (car quit running) and im wondering if I should change the head gaskets or intake manifold(for its famous leak) Car has 116k miles.
Is there a way to check either of these at the present situation?
Thanks,
Joe
Old Jun 13, 2007 | 08:53 AM
2000GTP's Avatar
If you had the notorious intake leak, it would be pretty noticable as oil would be present at the rear of the manifold. As for bad head gaskets, you can usually get the warning signs if you notice there is a mix of coolant in the engine oil. Frankly, if it isn't broke, I would just leave it alone.
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jul 30, 2017 11:46 AM
ModdedNerd
Jan 29, 2015 07:23 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
blac94Z
Nov 24, 2014 07:12 PM
