How do I spin the motor by hand?
I have a '94 LT1 motor and I was wondering how do i turn the motor over by hand? There is not a crankshaft bolt to hold on to. All i see are these 3 small bolts on the crankshaft?
Get a 5/8" socket, that will fit on the bolt in the crank snout. That would be the hole in the middle of the crank pulley. You can put a breaker bar on that and spin by hand. The other thing you can do is get a tool that turns the engine using the teeth on the flywheel. You take the flywheel cover off, then the tool hooks onto the flywheel and you turn the motor.
I would suggest the breaker bar on the crank snout though.
thanks that helps, i didnt think there was a bolt in the middle of the pulley, i guess i was wrong. Also how tight should that be? Is there a certain tq. that should be applied for the motor to spin? I think i may have seized my motor I just need some tips on how to make for sure.
Well what was the oil pressure like when you heard knocking? Any roughness in the motor or felt like it was missing? I really don't have much experience with knocking coming from the motor, but I'd pull the valve covers off and have a look at the valvetrain first. If that all looks ok I guess it would have to be in the bottom end
well the oil pressure gauge along with other gauges dont work. Its a v6 to v8 swap with lots of wiring issues i beleive. It will only start when I disconnect the TPS wire from the pcm. This may be why it sounds like its knocking. Any helP?
Victor Lamb
Aug 26, 2017 02:52 PM
cyteone
Feb 7, 2015 06:04 PM
Dec 1, 2014 08:08 AM
