How do I set the Timing...
Old May 8, 2004 | 05:51 PM
TrouserSnake's Avatar
The Timing has to be off on POS lt1 I cant think of anything else
Is there a site or service manual I could get that tells how to set the Timing.. For the price It would cost to get it towed to macanic I could Get a 500 horse Agositino motor
Old May 8, 2004 | 05:52 PM
Im talking about the Intail Cam Timing BTW
Old May 8, 2004 | 05:55 PM
ibanez6rg's Avatar
Evidently your timing dots aren't lined up on the timing chain. Otherwise, timing is controlled by the PCM.
Old May 8, 2004 | 06:07 PM
The dots lined up on the cam but I cant remember If It got moved and I took back some or..
maybe I installed the cam on #6 TDC?
Im looking for any posible veriables
Old May 8, 2004 | 06:17 PM
ibanez6rg's Avatar
As long as the cam gear dot and crank gear dot line up as they come around facing each other (#6 TDC), that part is fine.
Old May 8, 2004 | 06:36 PM
Is this correct yes or no??
When the 2 dots lined up.. The #1 one piston was on the compresion stroke and was starting to blow my finger out of the spark plug whole... When The two dots where perfectly alined I slid the old cam out and slid the new one in.
Old May 8, 2004 | 07:50 PM
Stare at this until it sinks in.
Old May 8, 2004 | 08:19 PM
toegead93's Avatar
i'm dizzy
HectorM52
Jul 30, 2017 11:46 AM
z28leno
Mar 12, 2015 07:42 AM
FredM
Mar 6, 2015 03:04 PM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
Jan 23, 2015 01:13 PM
