How do I rig a switch to manually lock my TC?
Old Mar 18, 2003 | 10:49 PM
Markolc's Avatar
I want to lock my TC in 3rd at WOT for dyno purposes. How do I go about it? BTW I have a 700-r4.
Old Mar 18, 2003 | 11:31 PM
Prorac1's Avatar
Theyre should be a wiring harness coming from your tranny, use a manual to figure out which wire controls lockup, (in my 94 it was the brown one, but you shouldnt have many wires to pick from being a 700r4) run it inside the car to a toggle switch (dosent have to be anything special, its just a ground circuit) run into the switch, with the wire from the tranny and than out the other post to a good ground, oh, and by the way, it needs to be a 2 position, two blade switch, hope this helps, prorac1
Heathen1
Jan 2, 2016 04:27 PM
Jeff'SS
Jun 1, 2015 06:21 AM
dylan1303
May 22, 2015 12:24 PM
Redbird
Sep 5, 2002 08:36 PM
