How do I remove my crank hub?
Old Sep 3, 2005 | 12:42 PM
Black94mula's Avatar
I wanna remove it to take the timing cover off to change all those seals.
Btw, what do i need to do, just loosen a few oil pan bolts to get that cover off? Thanks.
Old Sep 3, 2005 | 12:49 PM
Z95m6's Avatar
Re: How do I remove my crank hub?
Lots of people use stick 1/4 drive extension into the hole of the crank hub and push off of that. As for oil pan i would take almost all the bolts off on the pan. If you don't drop the pan enough and rip the oil pan gasket you'll have a lot more work on your hands.
Old Sep 3, 2005 | 12:53 PM
Okay that sounds good. Yea I've been a little hesitant to remove the whole cover because of the oil pan leaking later. But then I just got fet up and decided I have to do it, I think some of the seals are leaking on the opti. So if I drop it enough, and it doesn't rip the gasket, it should be fine later eh? I thought I might have a problem if I even disturb the gasket.
Old Sep 3, 2005 | 01:12 PM
Z95m6's Avatar
As long as you don't rip it you should be fine. I suggest putting some silicone where the timing cover meets the block, right where the oil pan gasket runs. I would try to replace the seals with the cover on the motor if thats all thats leaking.
HectorM52
Jul 30, 2017 11:46 AM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
