How do I know if this is really a LT4 shortblock?
Old May 7, 2004 | 12:39 PM
ONELOUDKAR's Avatar
Looking at purchasing a block but how will i know if it is really a lt4 shortblock. Are there any casting numbes anywhere to determine this?
-Mike
Old May 7, 2004 | 12:53 PM
sharpe's Avatar
To tell you how stupid I am, I thought an LT4 and an LT1 were the same block.
Old May 7, 2004 | 12:54 PM
Pasky's Avatar
Ummm, I think they are....Other than the casting #.
Old May 7, 2004 | 01:15 PM
Eddie95Z28's Avatar
LT4 blocks have 4-bolt mains. Other than that they are the same.
But he manetioned it was a shortblock... If so then then the crank and some other things are different.
Old May 7, 2004 | 01:16 PM
thrift23's Avatar
I think LT4's were 4 bolt main blocks.
Old May 7, 2004 | 01:19 PM
Nestromo's Avatar
A guy already told you how to tell them apart in the other thread. Go back and look.
Old May 7, 2004 | 01:33 PM
GREGG 97Z's Avatar
Here's some facts and part numbers on the two, I didn't see anything about a part # on the block but maybe the other facts will help:
http://www.grandsportregistry.com/lt1vslt4.htm
Old May 7, 2004 | 01:43 PM
96capricemgr's Avatar
The shortblock may be different but who cares anyway since the power was in the topend not the bottom. 4 bolts, who cares given the power guys are making with 2 bolts the 4 bolts aren't going to help anything anyway. Just my $.02
Old May 7, 2004 | 02:48 PM
Mtrhds94Z's Avatar
This thread already covered it as well as it's going to be covered:
http://web.camaross.com/forums/showt...hreadid=258503
I know the eyebrows[valve reliefs] in the tops of pistons are smaller than an LT1, also see this post:
http://forums.corvetteforum.com/zerothread?id=798562
Specifically the ZXD cast into the front pad, seems like good info to me...
Block is a 4 bolt LT1 block basically, but crank, rods, pistons, rings, are different..
Old May 7, 2004 | 02:54 PM
GREGG 97Z's Avatar
See the link. Even just the shortblock is different than an LT1 4bolt main shortblock. Different crank, timing set, camshaft among other small differences. If I was buying it I would want to know if it was really an LT4 if someone claimed it was.
Old May 7, 2004 | 03:23 PM
ONELOUDKAR's Avatar
Yes, the ZXD was what I was wondering about. Will it be stamped on the block itself or on a head? I will not be getting the heads nor the cam with the block, thats why was wondering.
ZXD is for a 96 LT4 manual and thats why I am asking, hoping it is stamped on the block somewhere and not the head!
-Mike
Old May 7, 2004 | 05:04 PM
JasonL's Avatar
I asked the guy from the vette forum. He said it was stamped on the block.
Old May 10, 2004 | 07:12 AM
ONELOUDKAR's Avatar
Thanks for checking JasonL!
Old May 10, 2004 | 01:54 PM
Mtrhds94Z's Avatar
Ihink it's on front pad of the block by psgr cyl head..
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
jackpawt883
Jul 31, 2015 08:15 AM
