How do I know if my egr valve is bad?
The engine runs real rough when I'm going above 55mph on the highway. It runs perfectly under that speed. There's no problem with the front end either.
I've replaced plugs, and wires and it didn't help.
I checked the egr and at idle when I pushed up on the diaphram the engine stumbled some. Then I got the engine warmed up and had someond push the brake and gas at the same time and I didn't feel the diaphram move up.
Does that mean it's bad and is causing my engine to shake on the freeway?
Did I do it right?
Did I do it right?
Re: How do I know if my egr valve is bad?
stockssn2o
May 25, 2015 08:54 AM
