how do i install my lt4 KM?
Where is my stock knock module and where do I put this LT4 knock module? Ive got my computer out and I'm looking around and dont see where this thing goes ... Thanks in advance for the help!!!
Unplug the battery. Take a 10mm socket w/extension, remove the 2 bolts and take out the PCM from the passenger side of the engine compartment.
Pull the only small metal cover off the PCM (small 7 or 8mm bolt), and pull the stock KM. Insert LT4 KM. Reinstall the cover and PCM.
Enjoy!
Enjoy!
Originally posted by ibanez6rg
And then if you're wondering... "Why ain't my da-gum car startin'?" Plug you're battery back in! D'oh
:blah:
:blah:
Just isn't right to work on your car and not forget something!
Henson071
May 4, 2015 12:23 PM
