How do I cut off fuel supply?
Old Aug 19, 2011 | 02:46 PM
droptopz2894's Avatar
As the title says. I'm not sure of how to shut it off so it wont pump fuel when I turn the key over. Thanks.
Old Aug 19, 2011 | 02:48 PM
Guest47904's Avatar
Guest
Re: How do I cut off fuel supply?
Pull the fuel pump relay under the driver dead pedal.
Old Aug 19, 2011 | 03:11 PM
Mystery Bird's Avatar
A pair of scissors?
I would pull the fuse too.
Old Aug 19, 2011 | 03:13 PM
Or pull the harness connector for the pump and gauge under the car (if it happens to be easier to get to).
You could just pull the PCM IGN fuse, but it will kill power to the MAF PCM and TDM, also. It just depends on what you are doing, I guess.
Also, do yourself and everyone else that tries to respond to your posts-make a signature with some car info.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Bruhdz
Mar 24, 2015 02:15 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
