how to determine between LT1 and LT4 Intake
Old Sep 22, 2003 | 08:56 AM
scoobysnax83's Avatar
Beside the red powdercoating, how do you determine which is which? What is the casting number on the heads and intake supposed to be?
Old Sep 22, 2003 | 09:12 AM
Fastbird93's Avatar
I don't know any casting numbers or anything, but the intake runners are raised. You'd notice it when set side by side with a LT1 intake.
Old Sep 22, 2003 | 10:16 AM
So what would I look for? I feel stupid asking, but where are the runners?
Old Sep 22, 2003 | 10:50 AM
LT1 part # = 12552137
LT4 part # = 12550630
The "runners" are the intake passages in the heads - rectangular openings. On the LT4 heads, the "raised" or higher intake runners are fairly obvious when you compare them to the LT1 heads. But on the intake manifold, the difference in height is not as great, and it is harder to tell them apart, without the red paint.
Search for a post on the LT4 intake by "Arnie"... he has provided actual measurements and appearance differences.
LT1 vs. LT4
Old Sep 22, 2003 | 10:51 AM
madwolf's Avatar
....look for the magic number 12550631.
Old Sep 22, 2003 | 11:03 AM
I'm starting to think that I do not have the heads and intake that I thought I had. But I'm not sure yet, I guess I'll have to look for the numbers and see what's going on. Will the stock valve covers fit on a set of LT4 heads? And..... Would you all be able to tell by a picture of my engine bay?
Old Sep 22, 2003 | 11:12 AM
You really need to check the part #'s. Yes, stock LT1 valve covers fit fine on LT4 heads.
Old Sep 22, 2003 | 11:42 AM
Well, I'm at work right now so I cannot look at the part numbers. I don't think you can, but can you tell if they are or are not from this picture? I painted it this color, but it was the same red that I've seen on the LT4's. I will check part numbers when I get home. Don't crack on the manifold air injector block off, its only temporary
http://www.marines.dyndns.org/Scooby...Z/DSCF0002.jpg
Old Sep 23, 2003 | 08:10 PM
arnie's Avatar
Necessity is the mother of invention.
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
