How come my A4 doesn't have first as an option?
Old Mar 27, 2004 | 12:19 AM
Cerwin Vega Fan's Avatar
Question How come my A4 doesn't have first as an option?
Ok I have noticed on A4's you can choose from OD, D, 2nd, and 1st. However, on my car I can only go from OD, D, and then L. Why is that? Did something change later in years down the road for the A4's?
Old Mar 27, 2004 | 12:21 AM
LT1Brutus's Avatar
This is a commonly asked question you could do a search on. It is easy and FREE to modify it to where you can select first, though I'd recommend against it unless you have a built 4L60E. Long story short, do to EPA noise testing, cars with the 2.73 gear option versus the 3.23 came without the option to select 1st gear.
Old Mar 27, 2004 | 12:22 AM
Cmr0z28's Avatar
Cars that came w/2.73s = no 1st gear selection
Cars that came w/3.23s = 1st gear selection
Something to do w/noise requirements, I guess with the 2.73s in first gear it resonates more or something....
Old Mar 27, 2004 | 12:24 AM
I never knew the auto even came in 3.23's.
Old Mar 27, 2004 | 01:03 AM
b-stevens's Avatar
Oh yes, it does. I think I would have thrown in some 3.73's if I was stuck with the 2.73's
Oh well... Im sure I'll get around to it oneday
Old Mar 27, 2004 | 01:17 AM
Scream And Fly's Avatar
My auto has the factory 3:23 option.
Greg
Old Mar 27, 2004 | 01:33 AM
rock1501's Avatar
Greg
Mine came with 273`s but it took me about 2 weeks of having the car before the 373`s went in
Old Mar 27, 2004 | 03:52 PM
I have always thought of getting 373's. Do they make a big difference? And how much top end will I lose?
Old Mar 27, 2004 | 04:03 PM
rock1501's Avatar
I picked up 3 tenths.
I can only go about 150mph now but my redline is higher than stock cause of my cam.I would say you could still go 140mph or so in O.D with stock redline
Old Mar 27, 2004 | 04:19 PM
RamAir95TA's Avatar
If you want first gear, remove the console and take out the rubber stopper that prevents the shifter from physically engaging first gear. Problem solved.
Old Mar 27, 2004 | 04:24 PM
So I will be able to keep pulling my shifter and it just go back to the blank spot behind L?
Old Mar 27, 2004 | 04:45 PM
Flmac02Z's Avatar
Yeah...and if it doesn't just come out i've heard of people using a dremel to cut the piece that blocked out first.
But yeah, once it is out you can just pull the shifter into that blank spot.
I was gonna do it but then I decided i'm gonna sell my car and get me a 6 speed.
~Kevin
Old Mar 27, 2004 | 04:48 PM
I have been told this might hurt my transmission. I take it though people hurt their transmission by putting it in first and just running it to hard right?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Victor Lamb
Aug 26, 2017 02:52 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
Jun 6, 2015 08:27 AM
F'n1996Z28SS
Jun 3, 2015 09:39 AM
