how to check vacuum pressure
Old Oct 4, 2003 | 01:09 PM
b-stevens's Avatar
I have a ticking noise thats apparent at idle and increases with rpm's on load, i caught a thread that mentions bad lifters and to check the vacuum pressure.
What do i need to check it and how should i check?
Old Oct 4, 2003 | 04:05 PM
"Vacuum pressure" is kind of an oxymoron, isn't it?
Vacuum is the opposite/absence of pressure. You need a vacuum gauge hooked up to one of the vacuum ports on the intake or you can use a scanner or diagnostic software to observe the MAP reading and then convert it to vacuum.
Old Oct 4, 2003 | 05:19 PM
b-stevens's Avatar
Is there a certain type of vacuum gauge that i will need or can i just go pick up andy random type at an auto store
Old Oct 4, 2003 | 05:45 PM
A vacuum test gauge is what you want. It shoud come with some hose and maybe a few different size adapters. Don't get something that is meant to be mounted permanently inside the car.
Old Oct 4, 2003 | 06:40 PM
b-stevens's Avatar
thanks, how much should that cost and what should the readings be at
Old Oct 5, 2003 | 07:12 PM
2cub49's Avatar
probably about 20 dollars. As I recall 18 inches of vaccuum at idle dropping to 0 at WOT and 24 on deceleration. That was when we used carbourators but i don't think these things have changed.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
