how to check vacuum pressure
I have a ticking noise thats apparent at idle and increases with rpm's on load, i caught a thread that mentions bad lifters and to check the vacuum pressure.
What do i need to check it and how should i check?
"Vacuum pressure" is kind of an oxymoron, isn't it?
Vacuum is the opposite/absence of pressure. You need a vacuum gauge hooked up to one of the vacuum ports on the intake or you can use a scanner or diagnostic software to observe the MAP reading and then convert it to vacuum.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
