How to check vacum??
Old May 29, 2004 | 06:14 PM
"White Knight"'s Avatar
Alright where do you hook up those vacum testers? I would like to know how much Hg i have. To make sure i don't have an intake leak.
Old May 29, 2004 | 06:17 PM
I'm going to figure out why my car only runs 14.086 at sea level. I have a really bad high miss sometimes......from 5000-5800 is almost non existant--think it might be the opti........i don't know if it's ever been changed 128,000miles......should i just change it?
Old May 29, 2004 | 06:27 PM
OBE1 95Z28's Avatar
Vacuum gauge should be T'd into one of the vacuum lines, close to the intake manifold. A stock motor will pull about 19" of vacuum at idle.
I don't think an intake leak would be the cause of your car not pulling above 5K RPMs. I'd check your spark plugs/wires - look under your hood in the dark when the engine is running and look for arcing from the wires to the block.
If your car is stock, 14.0 in the 1/4 is pretty normal.
Old May 29, 2004 | 08:09 PM
I know the vacum leak isn't the high miss prob.....i'm pretty sure it's the opti--cause the car harder to start now. The car is not stock mods are in sig. But I wonder how bad the opti is hurting performance in the low range......it feels fine......but then again maybe i'm just use to a worn out opti? How much 1/4 time do you think i will drop after i replace the opti? will i be running about right for the mods?
Old May 29, 2004 | 11:25 PM
OBE1 95Z28's Avatar
The only power adders you have is headers/cat back. High 13's is probably the best you'll do. The opti doesn't add any power, maybe "replace" replace lost power if that's your problem. I'd suggest you go to Shoebox's webpage and use his procedures to check your opti signals.
http://shbox.com/1/4th_gen_tech1.html
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
