how to check resistance on power window switches?
Old Jul 8, 2003 | 11:25 AM
anasazi's Avatar
my passenger side window is slow AGAIN... this is the third one that i've done for that side all covered by warranty. i'll replace the motor and it'll work but not very fast, then gradually burn out till its time to get a new one.
how do i check the resistance on the switches? could they be making it run slow / like crap?
Old Jul 8, 2003 | 12:13 PM
chevroletfreak's Avatar
Yes it can make your windows run slow. All you need is a meter and a manual. A Haynes would even be enough.
Old Jul 8, 2003 | 12:25 PM
Here is a schematic. Just plug your meter into the appropriate location and read ohms when you operate the switch.
Notice that some connections are fed to the RH switch from the LH one, so you might want to check both switches and maybe wiring.
Old Jul 8, 2003 | 12:37 PM
Z28SORR's Avatar
Another problem is that people aren't greasing the regulator and rollers when they change the motor. Also check all the window positioning adjusters, they can be putting undo force on the window.
Old Jul 9, 2003 | 01:03 PM
anasazi's Avatar
this schematic is difficult to understand. does each power window motor ground out at the power window motor or does it go to a centralized place to ground out?
Old Jul 9, 2003 | 03:18 PM
The ground comes from another location and is fed through the switch on the driver's side. Battery and ground are reversed by the switch to the brn and drk blu at the motor to make them run backwards to roll the window up. The switches in the schematic make it a little hard to read.
capebuf
Jan 13, 2015 07:22 PM
XtremeLt1
Sep 13, 2002 08:50 PM
danielbmx
Aug 27, 2002 11:11 PM
x7x7
Aug 15, 2002 06:49 PM
MilkyClr69
Jul 29, 2002 10:01 AM
